Kick Starting a Thumper??? AHH!! HELP!
Old Jan 17, 2007 | 02:43 AM
spdrmns's Avatar
Default Kick Starting a Thumper??? AHH!! HELP!
so today i got my 93 Suzuki DR650S running (push started it with a buddy) and rode it around the block with no issues..
well lucky me this is the model with NO electric start! great....i weigh 160 punds and i am a weakling.. i cant figure out how to get this thing started using the kickstarter! its got a de-compressiong lever and all that ****.
any suggestions?
http://i21.photobucket.com/albums/b2...mns/DR6502.jpg
Old Jan 17, 2007 | 03:31 AM
bushmasterAR15's Avatar
Default RE: Kick Starting a Thumper??? AHH!! HELP!
Buahahahahahaha.....I have a hard time starting a cr450 sometimes, and I'm 200lbs!! Steel shank boots and a belt with 100lbs on it might help
Old Jan 17, 2007 | 11:05 AM
city worker's Avatar
Used to have an 81 Honda XL-500 "THUMPER", pull in the compression relief lever, kick it a few times to get rid of the cylinder presure, then as you kick down about a 1/3 or so on the way down release the compression reliefe lever, try this a few times, alwaays remember to turn the handle bares away from the kickstart side, have had my leg thrown into the handle bars on a compression stroke kick back hurts like hell [:@]
Old Jan 17, 2007 | 11:16 PM
Well............. did I help or hinder ????????
Old Jan 19, 2007 | 02:28 AM
spdrmns's Avatar
ya i tried that! but every time i realese the de compression lever when im kicking it i can never get it to go past the actual TDC cause the compression is HUGE! and now my leg hurts..so yes, you did hinder..lol...
Old Jan 19, 2007 | 08:15 PM
Dave K's Avatar
You'll get it. It is all in your timing on how you attack the kick starter and exactly when you dump the compression release. You will develope the "timing" for doing it and then it will be so easy, you can show off in front of your friends. One thing to never, ever forget. Do not, baby your leg when you kick it. If you do, it will try to show you that it is boss, instead of the other way around. Once you get it, it is like kicking a 175.
Old Jan 21, 2007 | 07:32 PM
spdrmns's Avatar
i just figured it out.. (i dont even need the compression lever!) thanks guys!
DecaturF3
Jun 30, 2013 09:43 AM
Turbulenz
Sep 14, 2010 10:03 PM
bambam
Apr 10, 2010 02:46 PM
jp_greenville13
Mar 22, 2009 10:53 PM
cbr*sealik84
Aug 23, 2007 04:29 PM
