Keys
You can have one made at any hardware store (I went to ACE), but they didn't have the one with the fancy plastic grip, it's plain metal. If you want the OEM one, you can order a blank one online or at the dealer as a regular part, then have it cut.
Um you lost the only key you had? Or you just wanna extra one just in case? If you lost it then unfortunately my friend you will need to remove your ignition and take it to the stealership and they will look up the numbers and cut you a key. Probably should take your title with you. If you wanna make a copy, good luck finding a store that carries it. I've searched high and low and cannot find one for my bike (01 F4i) anywhere, not the 5 hardware stores (including ACE) or 4 autoparts stores. I did however find some on eBay, but I dont need 10 of em. Good luck
