Jim Ahlman speedo re-calibrator
I just ordered a Jim Ahlman speedo re-calibrator for my CBR1000rr. I used one on my 2003 VFR800 and it worked great. Anyone using one on their CBR and if so, what percentage did you adjust for? I'm going to be using a 15t countersprocket, which I know will throw it off even more. His website has an Excell spreadsheet you enter the gear ratios into and the diamter of your rear wheel, I guess this gives you what speeds you should have at any given rpm/gear and you adjust from there accordingly. I was just wondering if anyone already knew, is the speedo off 10% from factory or how much?
Mine was the oddball -- dead nuts precise with stock gearing. Reads 10.5% happy with -1F +1R. I need to get a calibrator -- how much was the Gregg Allman?
ORIGINAL: chainstretcher
Haha, it rocks! I got the Speedohealer V3 with the remote switch. I'm pretty happy with it. I had a V2 on the 929 which had the recall but no battery memory and the switch was located on the unit.
