Japanes vs USA conversion
Old Apr 1, 2010 | 10:47 PM
bearcat283's Avatar
Default Japanese vs USA conversion
I have a '05 repsol shipped straight from the U.S. Air force Base in Japan. This bike was purchased in Japan and is spec'ed to Japan regulations, it is also in Km/h. I want to convert over to U.S. specs. because Japan regulates it's factory HP to only 97hp. I have purchased an U.S. ECU along with the U.S. air funnels for the air cleaner (which are larger in Diameter). I was also told these will change the HP output. Is there anything else I would need to add or change to get the most from this bike? I'm also adding a PC3 and Yoshi rs5 complete exhaust system.
Thanks for any advise.
Old Apr 2, 2010 | 11:23 AM
skoobydoobie's Avatar
The speedo is an easy fix, just hold in the top button till it changes to mph. (might be the bottom button, I can't remember sht) Also the injectors may also be different, I dunno, I'm just speculating. If it needed less air, then it needs less fuel too right. That may be controlled by the ecu, and/or smaller injectors.
Old Apr 4, 2010 | 12:34 PM
gotcbr's Avatar
Wish you the best of luck w/ this. Back in the 80's, I wanted to import a right-hand drive RX7 but was met w/ all sorts of hurdles. Finally gave up on the idea. I hope things are easier these days w/ importing vehicles/bikes.
Old Apr 7, 2010 | 09:23 AM
^ much easier when you're in the military.
DopeBoy239
Jun 26, 2010 12:06 PM
bammerman
May 27, 2010 04:40 PM
riceabove2
Dec 12, 2007 07:37 AM
chuckb
Apr 30, 2007 08:52 PM
steve00ses
Jul 17, 2006 04:11 PM
