idle problems
Old Mar 24, 2008 | 04:41 PM
jabs83's Avatar
Default idle problems
My seems to be idling roughly. Heres the backstory:
I own an 88 cbr600f hurricane. I crashed it a few weeks ago, and afterwards it idled at very low rpms. I got it home, and adjusted the idle screw to get the idle around 1500rpms.
Even though I got the idle adjusted, the engine cant seem to hold a steady rpm. The needle on the tach fluctuates. And sometimes even dips below 1500 and rises back up after i give it some throttle.
This is my first bike, and very new to maintenence. What should I do to get my bike to idle at a steady rpm? What should I check, and what maintenence would be required. Any help would be appreciated.
Old Mar 24, 2008 | 06:41 PM
fireblade929's Avatar
Default RE: idle problems
well if you crashed you must expect that some damage was done to the bike. start by getting a service manual and check your fuel system (carbs, airbox, fuel lines etc) if you adjusted the idle screw and it died again then something must be wrong.
Old Apr 7, 2008 | 06:49 PM
winks900rr's Avatar
try to sink the carbs back
m21oliver
Oct 1, 2018 10:52 AM
harris7139
Nov 9, 2011 06:13 AM
ReSpEcT
Dec 15, 2007 09:32 AM
Mike_Stunts
Sep 24, 2006 11:47 PM
