i tried to replace the fuse and didnt work
RE: i tried to replace the fuse and didnt work
i had posted before that my guages dont work (my clock and blinkers and highlight led work), but the guage itself doesnt work, or the odometer. someone told me to try to check the fuses and i did. indeed there was one fuse that was broken inside it was by itself (not in the box) a it says 30 on it, but when i put the new one nothn happened. so im thnking maybe i need to reset my ecu. when i unplugged my battery and plugged it backn again the odometer did go all the way and back, but thats it.
so i was thinking if anyone my have other opinions, or if resettin the ecu should do anything, or even what is that fuse that i change suppose to do b/c it makes sense that if i changed a broken fuse, it should make somethin work.
thank you so much people, you are great.
