I Need Internatrix Help!!!
Old Mar 20, 2007 | 12:38 AM
kcinobro's Avatar
Default I Need Internatrix Help!!!
I just bought a Internatrix alarm fo my 06 F4i. I heard that it's pretty easy, but I'm not too familiar with the electrical tech of my bike. It says that wires are to be connected to:
-Frame Ground???
-ACC on the key switch???
-Coil, kickstand interlock, ignition module???
-Directional signal wires???
I'm not even exactly sure how to connect to the + and - on the battery. I was just wondering about how much I have to take apart to get to these connections.
I'm sure it's simpler than I think but my first glance at my battery left me in UTTER CONFUSION:
If anybody can tell me where to start I would greatly appreciate it.
Old Mar 20, 2007 | 02:04 AM
D2VW14_20's Avatar
Default RE: I Need Internatrix Help!!!
Red wire to positive on batter, black to neg.
HEre, I have an alarm install on here, it may help a little
https://cbrforum.com/m_217694/tm.htm
Old Mar 20, 2007 | 02:06 AM
D2VW14_20's Avatar
-Frame Ground???
Frame ground = any bolt on the frame
ACC = underneath the keyhole, wire going to it
Kickstand = wire sensor on going to kickstand underneath on the side
Direction Signal = turn signals.
Old Mar 20, 2007 | 04:02 AM
kcinobro's Avatar
Thanks man. I'll be getting back with you once I get another chance to mess with it. From the looks of things, I'll have wires going all over the place.
Old Mar 20, 2007 | 08:28 PM
kcinobro's Avatar
Update: I just did a minimal instalation for the alarm (+ and - connection, along with the ground wire to the frame) just to make it functional.
Questions:
1. I still don't know where to find the ACC wire. I looked under the ignition switch and noticed a bundle of wires coming from it. Is there a partiular wire (color) that I need to cut and connect with the wire from the alarm? Can I find that same wire closer to the battery?
2. Same question for the kickstand. I saw a set of wires (one was green and the other was green with a white stripe). The alarm has two wires that aresupposed to connect to the "kickstand interlock" and the "ignition module" in order to funtion the ignition disable function.
3. What color wires are for the directional signals? Will the front signals flash even if I use the wires from the rear?
My main concerns are making sure I can find and use the correct wires, and also I'm not too experienced in merging two seperate wires to another wire. Please let me know what the proper procedure is for connecting these wires.
4. And also, the alarm is very sensitive. I turned the sensitvity screw down, but it still goes off even when I just walk by it. How much of the sensitivity wire should I cut off? Or should I just cut it in half?
Old Mar 22, 2007 | 04:11 PM
kcinobro's Avatar
Does anyone have a wire diagram for the 06 F4i?
caddylicious
Dec 17, 2009 04:53 AM
dcen
Oct 14, 2007 10:27 PM
jimd2p
Feb 15, 2007 02:45 PM
D2VW14_20
Dec 5, 2006 03:11 PM
Feb 2, 2006 05:33 AM
