I can't turn the key in the ignition on my 2001 CBR 929RR to the on position.
Old Feb 11, 2016 | 03:00 PM
Ruthless1's Avatar
Default I can't turn the key in the ignition on my 2001 CBR 929RR to the on position.
I can't turn the key in the ignition on my 2001 CBR 929RR to the on position to start my motorcycle. I have already squirted WD40 into the ignition. That worked the first time that I used the WD40, now I still can't turn the key in the ignition to the on position.
Old Feb 11, 2016 | 03:38 PM
74demon's Avatar
Are the bars locked?
Old Feb 11, 2016 | 04:29 PM
Ruthless1's Avatar
I can unlock my handlebars with the key. I can turn the key to the OFF position without any problems. I can't turn the key to the ON position to start my motorcycle.
Old Feb 13, 2016 | 09:20 AM
Conrice's Avatar
Post a picture of your ignition... Does it look like someone tried to mess with it?
In college, someone tried to steal my bike by trying to hammer a flathead screwdriver into the ignition... I had issues after that with the key...
Old Feb 18, 2016 | 11:12 PM
coalminer frank's Avatar
Im sure you tried it both ways. Also dont stick it in all the way "thats what she said". One of my bikes is like that, you stick it in all the way, it wont turn, but if I pull it out just the slightest bit it works.
Old Feb 19, 2016 | 07:35 AM
Ruthless1's Avatar
I'll pull the key out slightly, and try to see if my key will turn in the ignition tonight. Thanks.
Old Feb 22, 2016 | 08:28 AM
Ruthless1's Avatar
I tried pulling the key out slightly from the ignition, and tried to turn the key to the ON position to start my motorcycle with no success. My key still won't turn in my ignition.
Old Feb 22, 2016 | 10:07 AM
Not meaning to ask a potentially offensive question but, are you positive you are using the correct key?
Old Feb 22, 2016 | 10:12 AM
74demon's Avatar
Since you can turn the key from lock to off, then something in the housing must be broken.
Old Feb 22, 2016 | 07:33 PM
How wore is the key? Maybe its not "defined" enough. Maybe get a blank and cut it yourself with a dremel so its really sharp and defined. Maybe.
Deltemis
Apr 22, 2012 07:48 PM
PurpleKnight
Oct 8, 2010 07:33 PM
Zach
Apr 5, 2009 09:48 PM
metallica81
Nov 4, 2008 05:50 PM
vaggabon
Jul 12, 2008 11:38 AM
