i aint that bright!
Old Feb 5, 2006 | 10:55 AM
icelee's Avatar
Default i aint that bright!
Anyone give a guide how to drain my fuel on my cbr 600 please id be really grateful i dont wanna try it and mess something up!!!. Thanks all honda gang[&:]
Old Feb 5, 2006 | 12:01 PM
Repsol1's Avatar
Default RE: i aint that bright!
I think its easiest to just siphen the gas out. I use an old fuel pump.
Old Feb 5, 2006 | 12:17 PM
speedy's Avatar
keep it running till it dies out
Old Feb 5, 2006 | 12:46 PM
AdeQ8Styl's Avatar
Run it until its empty. You have to ride it though. The idle RPMs werent enough to keep the battery charged when I was running the last bit out before I got deployed. I had to charge the battery back up then ride it around the block.
Old Feb 5, 2006 | 04:03 PM
icelee's Avatar
thanks all but i want to drain the fuel because it wont start
Old Feb 5, 2006 | 05:03 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Not sure of your model -- if it's gravity fed just clamp the fuel hose, disconnect and drain in an old milk jug. If you gots a fuel pump disconnect the fuel line after the pump (wait a while after you shut it down to bleed off residual fuel pressure) and let the pump drain the fuel for you. You might need some extra hose to reach to the jug. Reconnect everything and start her up to get rid of anything left in the carbs or injectors and fuel lines.
Old Feb 6, 2006 | 02:12 PM
icelee's Avatar
thanks ill try that all thanks alot
CBR_BULLET
Mar 9, 2012 10:26 PM
rangerscott
Aug 19, 2007 11:13 PM
SupaNda600
Jun 17, 2007 03:40 PM
freekymind69
May 6, 2007 11:55 AM
jcowick
Apr 1, 2007 01:36 AM
