how too test regulator/rectifier
Old Nov 3, 2008 | 05:37 PM
98cbr600se's Avatar
Default how too test regulator/rectifier
how would i test the regulator/rectifier on a 98 cbr 600
Old Nov 3, 2008 | 06:02 PM
HAVOC's Avatar
Default RE: how too test regulator/rectifier
if you look at the top of this very section. in the sticky section you will see a thread called " how to diagnose your charging system" click that and it will walk you through how to diagnose your R/R
Old Nov 3, 2008 | 06:37 PM
olboney17213's Avatar
Lay the r/r on a table with the flat mounting surface facing the table. You will see 3 prongs across the top and 1 prongon the left and 1 prongon the right on the bottom. Use your dvm on the ohm's setting and go to function and go to diode check. Place the negative on the bottom left prong and then place the positive on each of the top three. Record your results. Now put the positive on the bottom left prong and then the negative on each of the top 3 prongs. Record your results. I'm not 100% but I think you should get around .450 ohms of resistance one way and nothing the other way. Each of the diode terminals should have the same resistance. If one has two little it may be going bad. Hope this helps. I had a problem with mine and this is how I diagnosed mine.
Old Nov 3, 2008 | 09:09 PM
98cbr600se's Avatar
thanks use to working on cars bikes a whole new thing 2 me
Fabio420
Jun 26, 2008 11:58 AM
Gearloose
Feb 22, 2008 01:32 PM
racer212
Sep 15, 2006 02:34 AM
dunn929
Apr 18, 2006 07:12 PM
mavric_337
Apr 5, 2006 09:17 PM
