how to remove swingarm...
Old Oct 25, 2007 | 12:45 AM
OneRedRider's Avatar
Default how to remove swingarm...
i ride a 05 600RR and i'm planning to have my swingarm powdercoated...is it difficult to remove swingarm from frame? pls help, thanks!
Old Oct 25, 2007 | 08:57 AM
ffingers's Avatar
Registered Users
Default RE: how to remove swingarm...
i just looked into doing this on my f4i because i am going to get it powdered as well...at least for the f4i, it's not too difficult....the main issue is there is a castle nut where the swingarm attaches to the frame...to buy the honda part is like $55 or something....now you can make one if you have a grinder and the correct socket size (hopefully a spare).....then on the whole, from looking at my service manual, doesn't look bad at all....
putting it back on looks to be a pain though because there is a handful of torque values for putting back on the castle nut, the lock nut, etc....
oh and it's also important to note that you'll have to find a way to support the bike seeing as rear stands use the swingarm....so either jackstands under the headers or if you have a garge, supporting by a strap on a beam....etc.....
hope that helps, it's not much but at least it's a start....find the service manual for the rr and it will help A LOT! post pics when you do it...
Old Oct 25, 2007 | 09:11 PM
marc0011's Avatar
For supporting the bike, I use a cherry picker and straps. While you have the rear end torn down, I recomendregreasingthe bearings in the rear end suspension.
Old Oct 25, 2007 | 09:47 PM
Jason748's Avatar
It's actauly very easy on the 600RR, teh only "special" tool you'll need is a couple of VERY large allen drivers, you don't have to remove the castle nut.
I would recommened getting new seals for the the piviot point and re-grease ALL the bearings. But it's really very simple.
Old Oct 26, 2007 | 05:10 AM
thanks for all your tips...
antatious
F2 Tech
Aug 23, 2010 05:31 PM
mike.p
Jun 25, 2008 12:48 AM
elcoomagnifico
Jan 4, 2008 08:44 PM
OneRedRider
Oct 24, 2007 04:18 PM
OneRedRider
How-To: Mechanical
