help me remove my motor/swingarm
okay well i have my motor completly loose from the frame. i am trying to figure out how to loosen the swingarm from the motor. i want to leave the swingarm attached to the bike via the rear shock and just pull the engine... or is there a better way to go about his?? please help!! thanks in advance
RE: help me remove my motor/swingarm
I always use a pair of vise grips and hex nut. Just find a hex nut that fits into it and then clamp it into the visegrips and your good to go. or you can use a bolt with a hex head that will fit it. ace, lowes, home depot, just about any hardware store will have one to fit.
forgot to say if you use a bolt with the hexhead to fit, then you use two nuts on the thread and back one onto the other and use that with a wrench to loosen the swingarm bolt. Visegrips dont work as well on a bolt, and you can return the bolt and nuts when your done.
