how much can you lower the front end
Old 06-12-2006, 05:18 PM
sauce's Avatar
Default how much can you lower the front end
I've already dropped the back end on my girlfriends bike so she could touch the ground easier, but I am wondering how much I can drop the front end so she can touch the ground easier. Twice now she's come around a corner with some jackass in the wrong lane and she's dropped it. I figure another 1/2" or so would work out well, but to do that, I'd have to drop the front about 1". Is this too much? Am I going to run into issues with too much slack in the brake cables? I could tighten up the front suspension so I doesn't bottom out so easily... also since she is a new rider, she's not into wheelies, and what not.
How much does dropping the front end affect the handling? I know you decrease the angle, and the front end becomes unstable, but isn't the rake set by the triple tree?
Thanks for your help
Sauce
Old 06-12-2006, 09:04 PM
Default RE: how much can you lower the front end
Here ya go. \
Read this. Very informative.
http://www.sportrider.com/tech/146_0210_lower/
Old 06-13-2006, 02:58 AM
I wouldnt go more than 1"
as the clearance will be affected too much and if you hit a bump the front wheel might hit ur radiator/fairings
pipedcbr
04-25-2011 05:37 PM
VALKYIE
12-23-2008 03:25 AM
Rated R
08-31-2007 02:34 PM
GraveyLastGearMC
05-17-2007 10:31 PM
BoostinFD
09-30-2005 09:11 PM
Quick Reply: how much can you lower the front end
