How heavy is CBR F3 engine?
Im not 100 percent sure, but I think they are around 120 lbs or so. It all depends on what you are including on the engine as well. Carbs, header, wiring, cooling, ..ect. It will all add up.
Most shipping companies will have a range fora given price. I'm sure your in the 100-150lb range. Keep in mind they will also take the pallet into account as well.
Some companies will also charge based on size along with weight.
You should beable to call them up, tell them the basic dimensions of the engine and they should be able to give you quote. Engines get shipped all the time, so they should have an idea.
