How do I put Sea Foam in my carbs?
Old Jan 29, 2007 | 12:32 AM
TennesseeCBRF2's Avatar
Default How do I put Sea Foam in my carbs?
I've read that the best way to clean your carbs is to run Sea Foam straight into the carbs. So how do I do this? Should I run it into the fuel line (I have the gas tank off)? Any help anyone could give me would be appreciated.
Old Jan 29, 2007 | 05:25 AM
mdfirefighter's Avatar
Default RE: How do I put Sea Foam in my carbs?
Pour it in with the gas like it says on the bottle.... *shrug* maybe. But since you have the tank off that might be a bit hard....
MDFF
Old Jan 29, 2007 | 06:19 AM
bushmasterAR15's Avatar
Im not so sure that is the "best" way. I have never really worked with sea foam, dont get me wrong I hear its good, but any grime from your carbs will be running right into your cylinders and through your whole system. The "best" way is probably to remove them and clean them, not the easiest waybut it keeps the gunk off your internals.
Old Jan 29, 2007 | 08:41 AM
Bobthebiker's Avatar
Bushmaster, you're right on the money. seafoam is the easier way, but a full carb teardown and hand cleaning is the RIGHT way to fix any issue in there, and catch other issues before they become issues.
Old Jan 29, 2007 | 11:00 AM
I wanted to put some in there while the bike was running to clean them the EASY way. I appreciate your concern about the easy and the correct way to do it, but I want to know how to put this stuff directlyin my carbs while the engine is running.
My bike is 14 years old and is pretty beat to hell. Not like I'm trying to ruin it or anything, but I'm willing to try a $6 fix over several hours of disassembly.
Old Jan 29, 2007 | 09:01 PM
mikey1297's Avatar
pour it into the carbs while the bike is running untill it chokes the bike down then pour the rest in the carbs and wait awhile and crank it up and it will smoke white smoke like crazy then then it should clear up
MarkR
Oct 29, 2018 11:34 PM
jpanside@gmail.com
May 23, 2009 09:54 PM
f3mulatz
Aug 20, 2007 11:16 PM
Murph317
Sep 8, 2006 07:22 PM
SEAN_VANCE
Jul 31, 2006 12:10 AM
