Honda Swingarm Tool Dimension Question
Old Feb 19, 2011 | 10:06 PM
justasquid's Avatar
I don't think a 32 is large enough.
I know its a very simple tool and I hate buying tools that are so simple, but they are fairly inexpensive. You can get em on ebay for under 20 bucks. I would probably just buy one. Or go to your local dealership and ask one of the mechanics if you can borrow one. Many times, they will lend out their tools. Just keep in mind that they are their own personal tools and they may not lend them out. But its worth checking at the service counter.
If this helps, the tool should be a 5.8X47mm. Part number 07YMA-MCFA100. At least thats whats 04-05 is. They should be the same.
Old Feb 20, 2011 | 01:02 PM
justasquid's Avatar
Oh that distance.
You can make it whatever you want. You just have to compensate for the added length to your torque wrench.
Such as, if the torque value is 45 ft lbs, and you make the distance 1 inch. All you have to do is compensate for that distance by adding that one inch to the length of the torque wrench.
So, if your torque wrench in 12 inches long, you would multiply 12 by 45 to get 540. Then, since your length is one inch, you would add that to the 12 giving you 13. So take 540 and divide that by 13 which gives you 41.5. That is your new torque value to shoot for. So, you can make that distance any amount you want, just compensate for it. If you make it 2 inches long, your new value is 540 divided by 14 which would be 38.
Aweasel
Mar 7, 2009 05:37 PM
honda f4
Jan 24, 2009 12:32 PM
Vindoo
May 16, 2007 04:46 PM
