Honda cbr600f 1990
Old 04-03-2019, 01:53 PM
ignoakes46's Avatar
Default Spark plugs
Sorry for bad picture but it's all I could get.
Compression is good thank God and all near spec.
1 spark plug is exhaust side
2 spark plug
3 spark plug
4 spark plug is chain side
As you can see:
1&2 plugs are black.
3&4 plugs are orange ish.
I've just adjusted float height as all were pretty out by 2mm and 3mm.
Could this be my problem also is there anything else I should check when I sync the carbs this weekend and clean the fuel lines and tank out.
Cheers pal
Old 04-04-2019, 04:34 AM
coward's Avatar
If it´s a 1990 US model then 38 and 110 might be correct... https://www.bike-parts-honda.de/hond.../E_17_1/1/2925
I´d have a look at idle mixture screws as well...
.... and check if the float valve plungers move freely as this might effect float height!
Cheers from Austria!
Old 04-04-2019, 05:21 AM
CaBaRet's Avatar
2 spark plug
3 spark plug
As you can see:
Cheers pal
Yeh those 3 and 4 plugs look really lean ,almost to starvation, if they were getting fuel but no spark would at least come out wet ,looks like their just sparking,were both float needles working properly when you did the float heights?are you getting any back firing
Old 04-04-2019, 07:05 AM
ignoakes46's Avatar
Yes it does back fires but sounds great on deceleration..
Lol.
I'm going to Scott bride the ports so the needles don't stick as they do alittle
Old 04-04-2019, 07:18 AM
CaBaRet's Avatar
Is that Scotch Brite, as I had visions of a Scottish Wedding
Old 04-04-2019, 07:23 AM
ignoakes46's Avatar
LMAO I meant that.. not very good with spelling 😂
Old 04-04-2019, 07:31 AM
CaBaRet's Avatar
Just guessed it was one of those predictive phones (which I cant use)
Old 04-05-2019, 01:25 PM
ignoakes46's Avatar
Hi again.
So I got down to doing a compression and all cylinders were 90psi.. around 8-10 clicks
they should be 185 or so.
I did do it without exhaust and carbs off the bike
Have i done something wrong?
Can u please let me know cheers.
Old 04-05-2019, 01:29 PM
CaBaRet's Avatar
Which compression tester do you have
Old 04-05-2019, 01:32 PM
ignoakes46's Avatar
£15 one of eBay. Struggles to screw all the way into cylinder though
Quick Reply: Honda cbr600f 1990
