Help someone
I need a front wheel for a 01 929 i found a front wheel foe a 03 600rr before i buy the wheel does anybody know if it will fit my bike for sure i was told that it would but i need to use the 929 axel and bearings but i would like to know for sure thanks ahead of time
I wouldn't think so. I cross ref. the part numbers and they do not match. Normally, if the parts interchange between models, they will carry the same part number and these do not.
thats not 100 percent they won't, but I wouldn't risk it.
Guest
Posts: n/a
Probably you are getting no answers because no one knows or would bother trying it ...
justasquid is correct in his post .... if the numbers are different , the parts will not be the same most of the time ....
The wheels are prolly very similar , but axle lengths, spacers and bearings ect prolly are not going to be the same ...
It will be the dia of the axle and fork bottoms that will cause the biggest issues ...
If I were you , I would either go take your existing wheel assembly with you to check it out personally , or just search for the right wheel mate ?
Sorry we cant seem to be of much help , but it would be considered an unusual question to say the least .....lol
good luck ...
good luck ...
