help needed
Old Sep 20, 2014 | 10:04 AM
Goon Chris Hollands's Avatar
Unhappy help needed
i seem to get a bit of juddering under acceleration when my headlights are own any one no wot could be causing this thanks
Old Sep 20, 2014 | 11:43 AM
Conrice's Avatar
wut?
Your headlights are always on, or at least, they're supposed to be.
Old Sep 20, 2014 | 12:01 PM
hawkwind's Avatar
Hi Chris, you live in the UK?
Where do you feel the juddering? Through the bars or somewhere else and is it a judder or a splutter?
Might help us to help you if you post up a little info, like where you live (a country will do), what bike you're riding and how long you've been a rider.
Welcome to the forum BTW.
Old Sep 20, 2014 | 12:49 PM
hi yer live in uk suppose it is more of a splutter when pull throttle bk when initially pulling of doesnt happen when the lights are off and soon as switch them on it starts been riding a month 2000 honda cbr 600
Old Sep 29, 2014 | 03:46 AM
wheelnut's Avatar
Welcome Crew
have you checked your battery, it sounds as if power is being taken from the ignition side when the lights are put on causing a splutter, I am no electrical guru but I would check the battery, then the charge going to it, then check all the earths and connectors to start with, no doubt an electrical guru will be along to help
Old Oct 5, 2014 | 01:12 AM
will try new battery
Old Oct 6, 2014 | 04:05 AM
wheelnut's Avatar
Welcome Crew
before you fork out for a new battery, just check the one you have with a multi-meter and check the charge going to it first before you spend out, my advise would be check the voltage going to the battery at about 3000-4000 rpm then turn the lights on to see how much the voltage drops.
Fubadu_the_Mighty
F3 Wanted
Jun 22, 2010 11:38 AM
jonnym61
Mar 4, 2010 01:36 PM
MattG
Aug 29, 2008 05:40 PM
barryem
May 8, 2007 01:55 AM
stilin
Sep 20, 2005 10:19 PM
