Help... lost my tailight/digital display
Old Apr 7, 2007 | 08:19 PM
Zac369's Avatar
Default Help... lost my tailight/digital display
OK, so I just put some rear flush mounts on, got everything connected, and i lost my tailight and digital display/nuetral lightand all other lights on the display. But I still have a break light, turn signals, headlight,and the clock is still working... I'm an idiot ... Help!? THANKS[/align]this is a 2006 cbr 600rr[/align]
Old Apr 7, 2007 | 09:00 PM
ChrisMcD's Avatar
Retired Admin
Default RE: Help... lost my tailight/digital display
Aftermarket signals typically have two wires while OEM or original equipment is typically a three wire setup. You need to make sure you are using the right wires if that is you situation. running the current through the wrong wires can short the system and cause the named problems you mention. There is a nuetral wire, a constant power(typically a solid color) and a switched power(typically solid color with a line through it) in the OEM setup. This provides the signal on the switched wire and the running light on the solid wire and the neutral is just that, completes the curcuit. The constant power is the one you will not be using with aftermarket signals. This wire will be capped off and un-used from this point on. Make sure your wired right. Test with a tester or let me know the setup and I will find the right wiring diagram for you. PM me with what color your wires are and if it is two wires on your flush mounts and three on the bike.
~Chris /Musichyp
Old Apr 8, 2007 | 02:17 AM
dragonium25's Avatar
OR...you've blown a fuse Phil Mickelson. Open up the fuse box behind the left fairing and replace the 10A one for the instrument panel, you should a spare.
Old Apr 8, 2007 | 02:18 AM
Zac369's Avatar
hey thanks alot man, turned out just to be a blown fuse thankfully. thanks alot though!
Old Apr 8, 2007 | 02:41 AM
Shalom
Lilkukic26
Mar 4, 2012 02:50 PM
wrighty92
Jun 28, 2011 09:38 AM
eggy9011
May 21, 2009 02:01 AM
ducatidcs
Dec 11, 2008 07:20 AM
shinysideup
Sep 7, 2005 08:11 PM
