is? HELP WITH FUSES OR WIRING
Old Dec 15, 2006 | 12:46 AM
kennethrieser's Avatar
Default is? HELP WITH FUSES OR WIRING
I have a 2005 Honda 600RR. I installed about 40 led lights on it. 10 pods of 4 lights on each pod. I wired these all parallel into a switch box, and then I ran that to the headlight, just to test to see if it would work. Now my regular headlight wasn't working to begin with, not sure what the problem is with it yet. Just got the bike. The high beam worked fine, up until I hooked the LEDs up to test the lights. Needless to say the LED's didn't work, and now my high beam doesn't work. What do you think the problem is? I think it could be a fuse, but where do I find that fuse on the bike? I looked under the seat but not sure if fuses for headlights would be tgere. Please email me at kennethrieser@yahoo.com, as I am not on here much.
Old Dec 17, 2006 | 03:52 PM
Billy Boots's Avatar
Default RE: is? HELP WITH FUSES OR WIRING
on my CBR 1000 the fuse box is under the left panel just under the handelbars , it sounds like a short circut .
Old Dec 19, 2006 | 03:28 AM
zerochickenstrips's Avatar
You should probably figure out why your low beam wasn't working first, prob. just a blown bulb. I imagine you def. blew a fuse. You need to check your wiring out.
vain1
Apr 30, 2010 11:08 AM
prhockey21
Mar 23, 2008 11:16 AM
pawnman
Jun 25, 2007 03:37 PM
tire_fryin89
Aug 13, 2006 06:11 PM
Anubis
Jul 30, 2005 08:58 AM
