help fast!!
Old 09-06-2010, 09:04 PM
justasquid's Avatar
Is your bike a california model?
If so, it appears to be the PAIR control valve. Im not 100 percent sure what it does, but is a pulse secondary air injection control valve. Its a smog thing. Again, Im just taking a stab at it as Im not 100 percent sure.
If gas is coming out of it, I would assume you have one or more floats stuck in one of your carbs.
Oh, and the hose doesn't go anywhere, its designed as a vented overflow and it dumps the excess gas out the line. the line is tucked away behind the water pump and out the bottom so the gas gets away from the bike. It should also be in a bundle of other hoses and they should be semi-pointed away from the rear tire.
Old 09-08-2010, 02:17 PM
greenheep's Avatar
The Bike originally came out of Texas. And would the floats sticking cause it not to idle? I've checked the idle screw, its fine. I'm currently down to the carbs now, getting ready to pull them and clean them. Wish me luck!
Metilj
07-08-2009 05:44 AM
cwmc29
06-28-2009 10:24 PM
Juliet
06-09-2009 09:31 PM
jasonty
07-09-2007 10:21 PM
rrasco
11-02-2006 02:10 AM
Quick Reply: help fast!!
