clutch problems,bike stallls, 01 929rr
Old Sep 8, 2010 | 07:29 PM
nsrt4me's Avatar
Default clutch problems,bike stallls, 01 929rr
new clutch,stalls when i put in gear??
put in a new oem clutch, put in same way as instructed and same way as old clutch came out. when i pull the clutch in the bike sounds weird, rpms drop evr so slightly. when i put it in gear its a hard click and the bike stall immediately. the adjustment on the clutch case is all the way out and almost all the way out on the perch by the lever aswell. if its not theres no tension in the clutch at all. whats wrong>>????please help!
Old Sep 8, 2010 | 07:59 PM
justasquid's Avatar
first thing I would check is to make sure the kickstand is not down when your putting it in gear. If thats not the case, I'd check to make sure your kickstand switch is not faulty.
But, since your adjustments are so far out, it sounds like something has happened internally. The next step I would take is to take the cover back off and inspect everything to make sure its correct.
Did you also replace the springs?
branstan
Jul 29, 2012 08:35 PM
Drippps
Nov 29, 2010 07:45 AM
budman1984
Mar 7, 2010 10:18 AM
lsybert
Jun 25, 2009 11:07 AM
JustinKP
Jun 21, 2009 10:06 PM
