Heated Grips for my CBR600 F3
Old Jan 7, 2013 | 11:25 PM
FOGeologist's Avatar
Senior Member and ROTM March 2014
Default Heated Grips for my CBR600 F3
Hello, team.
My new, 147-year-old F3 is in need of some heated grips.
There are about 83,500 options out there. Any youse guys have a direct experience you'd like to share? I've put grips on a bike before (used a great deal of WD40) so I'm not totally a nincompoop.
The impression I get is that you might want to stick with stock and get the flat heaters, gluing them on to the cleaned bar (left) and throttle (right). Is it tough getting the old grips back over the heater element?
Frankly, I'm not scared of wiring, as I'm pretty competent with 12v electronics. Any report of your personal experience will be welcomed. And yes, I did search the topic and got some encouragement from that.
Old Jan 8, 2013 | 05:16 AM
MadHattr059's Avatar
Whatever you go with, use a relay to be sure that they aren't drawing power
if the bike is turned off.
Personally I went with heated gloves (Gerbings). I installed a relay and
mounted a thermostat on the tripple tree, to have the most option.
Ern
Old Jan 8, 2013 | 08:38 AM
jeffjones's Avatar
I use heated grips and ride till the snow in Canada and these works awesome on my 45 min commute everyday.
Motorcycle ATV Snowmobile Heated Hot Handle Bar Grips | eBay
Old Jan 8, 2013 | 11:16 AM
CorruptFile's Avatar
June 2013 ROTM
You can use those handgrips jeffjones pointed out - basically 2 heater matricies that has a hi/lo/off switch.
As ern said, use a relay! I did up a quick wiring diagram for another user in another thread.
Old Jan 8, 2013 | 06:54 PM
I mounted this fused relay under my seat...
The black **** on the left is my heat controller...
Ern
Bordo
CBR1000F For Sale / Found
Jun 23, 2013 06:36 PM
Bordo
Oct 8, 2010 01:50 AM
partytime
Nov 6, 2008 07:52 PM
FfourI600
Oct 24, 2008 02:38 PM
llhank
Nov 7, 2006 03:02 PM
