Headlight just quit
Old Apr 23, 2009 | 07:56 PM
TankF4's Avatar
Default Headlight just quit
I have a 200 F4 and I turned my bike on today and no light. I put a new bulb in didnt work so i tested the light and it was good. I tested the plug and it says there is juice coming through. My question is where do I look next? I changed all fuses and checked wires also nothing pinched or bad. Thanx in advance..
Old Apr 23, 2009 | 08:28 PM
justasquid's Avatar
If you have power to the bulb, there is no where else to check. The connection between the bulb and the plug must be bad. Make sure the tab inside the plug itself is seated all the way. If the tab is loose, it will not make connection to the bulb.
How did you check the power to the bulb?
Did you use the ground on the plug?
Make sure the ground is good too.
Old Apr 23, 2009 | 08:35 PM
TankF4's Avatar
I used a volt meter it it came back with juice. Ya I used the ground on the plug also. The tabs inside the plug are really loose thought
Old Apr 23, 2009 | 09:34 PM
nessxp's Avatar
find a new socket!!!/Plug
Old Apr 23, 2009 | 09:56 PM
niner29's Avatar
or just cut the old plug of and use crimp terminals b/c i doubt anyone is willing to cut their plug off a good harness
user 3037347
Oct 15, 2009 04:34 PM
astroturf4
Jan 21, 2008 08:21 PM
mikeyvis
Nov 25, 2006 01:40 AM
mikeyvis
Nov 22, 2006 08:58 AM
olddog
Aug 1, 2006 02:36 PM
