headlight
Old Jul 4, 2006 | 10:29 PM
glempo's Avatar
Default headlight
Ok i need some help just cuz im lazy...how do i change the headlight on my f3, i just dont konw how much i have to take of to get to them..
Old Jul 4, 2006 | 10:45 PM
crookedeyemotocross's Avatar
Default RE: headlight
You will need to unplug it then remove the wire bulb clip (holds the bulb in place) looks like a bent up coat hanger (this is the best way I can describe it. Then pull out the old bulb, it will actually fall out. Then to re-install, while holding the new bulb in place re-install the wire retaining clip and plug the harness back onto the prongs on the new bulb and you are done. I recently replaced my headlight on my f3 and I went with a xenon bulb and could not be happier. Hope this helps, just be patient because it is a bit tight working in that area but it can be done without any plastic removal.
Old Jul 6, 2006 | 04:04 AM
glempo's Avatar
ok..do i have too take off any faring pieces?
cmartino88
Aug 1, 2012 06:39 AM
papa wheelie
Jul 20, 2011 11:16 AM
Davidth93
Jul 16, 2009 12:22 AM
cyber00677
Aug 3, 2007 03:57 PM
