headlight
You will need to unplug it then remove the wire bulb clip (holds the bulb in place) looks like a bent up coat hanger (this is the best way I can describe it. Then pull out the old bulb, it will actually fall out. Then to re-install, while holding the new bulb in place re-install the wire retaining clip and plug the harness back onto the prongs on the new bulb and you are done. I recently replaced my headlight on my f3 and I went with a xenon bulb and could not be happier. Hope this helps, just be patient because it is a bit tight working in that area but it can be done without any plastic removal.
papa wheelie
07-20-2011 11:16 AM
Davidth93
07-16-2009 12:22 AM
cyber00677
08-03-2007 03:57 PM
