Having a carb issue! Tech support needed!
Old Mar 25, 2013 | 09:01 AM
katt72's Avatar
Angry Having a carb issue! Tech support needed!
I'm having a issue with my 99 F4. During the initial startup, it will crank but die out within seconds of startup. Before starting, I put on the choke & make sure that the gas switch is on also. Once I press the ignition switch, it will fire up. During this, I have to give throttle to keep it started, but then it eventually dies. If someone who has been thru this dilemma, or who is mechanically inclined, please quote on this issue please.
Maybe helpful, or fix the issue!!
Old Mar 25, 2013 | 12:44 PM
cookml22's Avatar
Sounds like they might need cleaned, dose it run if you give it gas is the bike still rideable?
Old Mar 25, 2013 | 01:01 PM
katt72's Avatar
Default Have a Carb Issue
No, its not rideable, puzzling, once it dies, I can hear bubbling noises coming from the carbs. The carbs have been cleaned and synced.
Old Mar 29, 2013 | 07:09 PM
FOGeologist's Avatar
Senior Member and ROTM March 2014
It sounds like an idle circuit is plugged somewhere, or re-assembly was done in error. Who rebuilt your carbs?
Bubbling noises... Hmmmmm.
Old Mar 30, 2013 | 07:57 AM
If the carburetors were cleaned and sync'd last fall, and your're just starting the first time for this season, then it's possible they're clogged again. When were they cleaned ? To sync the carburetors, naturally the bike has to be running. When was that ?
Old Mar 30, 2013 | 09:17 AM
katt72's Avatar
When you speak of a idle circuit, where would that be located? FOG, could you give me in depth about the idle circuit, it would be appreciated.
Old Mar 30, 2013 | 09:24 AM
katt72's Avatar
Angry Have a Carb Issue
IDD, the person who claimed to clean and sync my carbs, is no longer working on my bike. The same thing you mentioned is the same reason he's not my mechanic anymore. It seems i may have to send to a Honda dealer to fix n repair my problem. If you know how it can be done without outside assistance, please advise with more info.
Old Mar 30, 2013 | 02:34 PM
stealthy92's Avatar
If you're up to the task of doing it yourself I'd say go for it. I have an F4 too and I learned slowly how to do it myself and I'm happy I did.
Here's a good how to: https://cbrforum.com/forum/how-mecha...r-carbs-40713/
and a diagram of everything with labels: http://www.hdforums.com/forum/attach...eihin_carb.jpg
Get some good carb cleaner and go to town. Or take it to the shop if you're not comfortable with doing it. Either way you need your carbs cleaned.
Old Mar 30, 2013 | 02:37 PM
Dean0's Avatar
I have first hand experiance of the the burble / or hissing sound when the engine dies.
One of your float needles has stuck or has crap stuck in it.
The burble/hiss sound is neat fuel comming out of the main jet and depositing itself on the back of the now hot valves !!!
I would not have beleived it until I saw it myself ( we were trying to start the bike with the top of the airbox off to see if we could see fuel. )
Once the float needles had been cleaned - and we made sure the idle jets were the correct size & clean - she fired up and ran like a dream.
CorruptFile's Avatar
June 2013 ROTM
Carbs are pretty easy to clean yourself. As long as you aren't totally ham fisted you can do it. Hardest part of the job imo is de-attaching/attaching the throttle cables. Do some googling and youtubing on cleaning carbs. There are tonnes of different designs but the principle is the same for all them.
Maybe another F4 owner here can advise, but is there a idle control **** for these?
