Hand grips
Old Aug 28, 2009 | 09:12 PM
cbrmeasap's Avatar
Originally Posted by johnnyx
They come in different lengths. You can't trim them, or you'll lose the rubber butt that matches up with the bar end.
Well, the next question is what size do I need? I've noticed that grips come in quite a few different lengths: 115, 120, 122, 125, 130, 135mm..
Old Oct 3, 2012 | 03:50 AM
Wattsycbr's Avatar
Registered Users
I've just been measuring and I think i need 120mm, do you recall which size you used?
Old Oct 4, 2012 | 11:38 AM
Incompatible's Avatar
Just measured my F4i and the 120mm length open end grips are correct.
Old Oct 4, 2012 | 05:21 PM
MadHattr059's Avatar
Check out Renthal and Driven. They both make quality gel grips.
Bar-end weights can help dampen vibration, as well.
Consider gloves with gel-pads, thrown into the mix.
Speaking of gloves...do yours fit properly? If they are too snug
across the palm, they can be cutting off circulation.
Consider a CrampBuster (or some other throttle-assist),
they keep you from gripping too tight (especially on longer distances).
Ern
Nlabella29
May 20, 2013 10:24 AM
Petterman
May 10, 2012 09:44 PM
Ratinacage
Aug 1, 2008 07:21 PM
lunerknight
Jan 23, 2008 08:45 AM
03yellow6000RR
Oct 31, 2007 01:49 AM
