Looking for hand grips
Old May 17, 2013 | 01:26 PM
Nlabella29's Avatar
Registered Users
Default Looking for hand grips
Hey all,
I have an 01 Honda cbr 600 F4i. My one hand grip on the throttle slides more when I go to give it throttle. So the actual hand grip slides more than the throttle if that makes sense at all. It's putting more strain on my hand. What are good quality hand grips I can purchase? I would appreciate your help.
Old May 17, 2013 | 03:08 PM
Aken's Avatar
July 2008 ROTM
Driven grips are my favorite. Either the diamonds for a normal style, or the D3's for a cool aluminum look.
Old May 17, 2013 | 03:15 PM
Nlabella29's Avatar
Registered Users
Thanks Aken! Any Diamond or is there a specific one?
Old May 18, 2013 | 03:11 AM
Aken's Avatar
July 2008 ROTM
Diamond Grippy are what I like, though I'm sure others are good as well.
Old May 18, 2013 | 10:28 AM
xtremef4i's Avatar
I like stock. Just make sure to use some grip glue
Old May 18, 2013 | 01:11 PM
kilgoretrout's Avatar
Administrator - Retired
I like my pro-grip gel ones. They beat the hell out of the stock ones for grip and comfort, and they're only like $15 or so.
Use compressed air to remove/install them. It takes like 2mins. I also used some hairspray inside my new ones to help them slide on and then stick. Don't know how much it helped, but they don't move.
Old May 18, 2013 | 08:50 PM
singram's Avatar
I've always replaced my grips with Pro-Grips using the above method with wifes cheap hairspray. I just replaced the F4i's last weekend as a matter of fact. Speaking of which, I STRONGLY recommend against using any kind of grip glue. The residue is a PITA to remove when it comes time to replace grips. Hairspray alone has always worked like a champ for me, and left no glue residue.
If the OP wants, I can post pics of the new grips.
Old May 18, 2013 | 10:57 PM
sjona2011's Avatar
+1 on progrip gel grips, theyre cheap, comfortable, and they fit a little tighter than oem so you really dont need to use any sort of glue.
Old May 20, 2013 | 10:24 AM
Nlabella29's Avatar
Registered Users
Thank you for your help. Never knew about the hairspray. Very cool.
mikey49
Oct 4, 2012 05:21 PM
Petterman
May 10, 2012 09:44 PM
Ratinacage
Aug 1, 2008 07:21 PM
lunerknight
Jan 23, 2008 08:45 AM
03yellow6000RR
Oct 31, 2007 01:49 AM
