Grind and rattle from rear end
I was wondering if your chain is supposed to make a rattle loud enough for you to hear when you first take off. The chain I have looks like it is tightened to the right spot but its also at the new chain warning on the little adjuster....
It makes a sound similar to brakes grinding and I wanted to know if that is normal or if I should replace my chain asap.
After that, check your chain alignment. If it is not aligned well, the teeth of your sprockets will catch on the edge of the chain and you will get some mean clunking noises too.
As well as what these guys said... lube/new chain, have around 1.5 inches of slack.
