Grease On Wheel Shafts
Old Jul 4, 2006 | 10:39 PM
Kingpat's Avatar
Default Grease On Wheel Shafts
I just got some new tires for my bike. I removed the rims myself and brought them at the shop the next day. So about 20 hours after I removed them, I noticed that the grease on the shafts got a little dry. I'm gonna get some grease to put on but should I wash the shafts with some WD40 first? And what kind of grease should I use?
Thanks
Old Jul 4, 2006 | 10:50 PM
ejohn's Avatar
Default RE: Grease On Wheel Shafts
the only reason for the grease is to make it easy for the next time you pull the shaft out.
Old Jul 4, 2006 | 11:09 PM
Kingpat's Avatar
I thought it was also to ease the friction from the wheel rotation. But what do I know hehe.
Old Jul 8, 2006 | 05:57 AM
Soarer's Avatar
Wheel rotation is aided by grease on the wheel bearings. Grease on the middle of the axle won't do anything to help. That being said, I coat everything with grease when I'm in there. I'd rather have too much grease than too little. Also, whenever I have something apart, I repack the bearings. With our bearings on cbr's, you'll have to remove the dust seal to really get at the bearings. This requires a special tool to remove them without damaging them. I don't have the tool, so I just stuff some bearing grease behind the dust seals. I use heavy axle grease that i got at the auto parts store. It's the same stuff that comes in the tubes that the grease guns use. Be careful using wd40. That stuff breaks down grease. If you use it, be sure to remove it all before you add your new grease. You should never lube anything with wd40. Only use it as a cleaner, then lube with a true lubricant like axle grease for bearings or silicone for cables.
Old Jul 8, 2006 | 06:31 AM
Ssaba420's Avatar
Good Stuff There ~ ^_^
fella
Aug 30, 2010 04:59 PM
black_98civic
Jan 12, 2008 12:18 PM
brianpreuss
May 26, 2007 12:27 AM
MT Wallet
May 2, 2006 06:50 PM
vortex1114
Mar 12, 2006 02:20 PM
