gettin tires of this #$%@
Old Jun 15, 2009 | 07:20 AM
utter05's Avatar
March 2009 ROTM
Originally Posted by armyranger
The choke on the bike is not wear it should be. Its just a cabel bye the pitlock and it works but you can turn it both ways and it will not stop. So I'm pist off turrning the ****ing thing floding the bike then it breaks.
The cable your talking about is NOT the choke it is your idle speed adjuster, the choke is up on the left handlebar. if you were turning it like crazy your idle speed could be jacked way up or way down which could be a problem as well.
The choke cable runs on the right side of the F3's and ends in front of the carbs right under the bottom half of the airbox. it is just a simple pull cable that attaches to a bracket on the front of the carbs. Now since you broke the cable the carbs must be pulled to replace it so you can get the idle speed set correctly.
Miawpukek
Nov 4, 2009 06:55 PM
cbrsix
Oct 8, 2008 08:53 AM
jrode
Jul 16, 2007 10:52 PM
Shortysboy09
Mar 31, 2007 09:34 AM
gofasteRR
Mar 2, 2007 04:09 PM
