GEAR SELECTION PROBLEM
Old Aug 31, 2008 | 09:25 AM
bigrich's Avatar
Default GEAR SELECTION PROBLEM
i HAVE A 1991 CBR1000f.when engine is cold the gear leaver will not return to its normal position,unless i give it a tap down with my foot.When engine is hot the problem gose away.Has anybody else exerienced this problem,dose it just need a oil change,or is it the return spring,is it a easy job,or is it a garage job.ANY ADVICE WOULD BE GRATEFULLY RECIVED,THANKS BigRich.
Old Sep 1, 2008 | 01:03 PM
lou_michelle's Avatar
Default RE: GEAR SELECTION PROBLEM
without sounding patronising.... have you tried just lubeing the lever??
bit of wd-40 or chain lube might just help free it up.
clean it all up first, check for any corrosion, if all looks healthy stick a bit of lube in and work the lever aorund a bit...
hopefully the simple things work the best for you
Good Luck
Old Sep 1, 2008 | 02:05 PM
Hurricane rider's Avatar
if it does it when cold, I'd look into fresh oil. cleaning and lubricating the assembly will certainly do it some good though.
OLI777
Aug 7, 2010 09:09 PM
mtm864
Oct 29, 2009 04:37 PM
Decah
Jan 29, 2009 01:21 PM
skitz047
Riding Gear
Oct 22, 2008 02:10 AM
jayking232003
Apr 22, 2007 03:42 PM
