GEAR SELECTION PROBLEM
i HAVE A 1991 CBR1000f.when engine is cold the gear leaver will not return to its normal position,unless i give it a tap down with my foot.When engine is hot the problem gose away.Has anybody else exerienced this problem,dose it just need a oil change,or is it the return spring,is it a easy job,or is it a garage job.ANY ADVICE WOULD BE GRATEFULLY RECIVED,THANKS BigRich.
RE: GEAR SELECTION PROBLEM
without sounding patronising.... have you tried just lubeing the lever??
bit of wd-40 or chain lube might just help free it up.
clean it all up first, check for any corrosion, if all looks healthy stick a bit of lube in and work the lever aorund a bit...
hopefully the simple things work the best for you
Good Luck
Good Luck
