Gas in oil?
Old Dec 25, 2008 | 01:58 AM
smitty911's Avatar
Default Gas in oil?
not my bike. its my step dads. its a katana 750 2001. his oil smells like pure gasoline. it has carbs so i thought it will either be something wrong with the needles or something inside the carb or maybe piston rings. any ideas?
Old Dec 25, 2008 | 02:14 AM
Hurricane rider's Avatar
Default RE: Gas in oil?
a carburetor or two has an inlet needle that isnt closing all the way, and its letting fuel flow through with the motor off. the fix is simple, pull the carburetors, clean them thoroughly, and make sure the floats are set to the right height, then reassemble. I'm not familiar with teh fuel system on the katanas, but he might try turning the petcock to off when he isnt riding the bike.
also change the oil.
Old Dec 25, 2008 | 02:24 AM
smitty911's Avatar
yea thats what i thought it was because he had a full tank when we put our bikes away about a month ago now its less than half a tank. thanks
Old Dec 25, 2008 | 03:20 AM
not a problem. while you're at it, add a paper or porous copper/bronze media fuel filter inline between your tank and carbs. the cleaning part as you probably know is very easy if you're mechanical and from what you've posted, I assume you are at least semi knowledgable in carbs.
Old Dec 25, 2008 | 04:05 AM
94cbr600kid's Avatar
ORIGINAL: Hurricane rider
1+ could also be if he has flooded it lately.causing it to fit up..but yes i could change oil ASAP.tell him not to start it with gas in his oil...it thins out the oil which is really bad and BOOM!..he wont have a bike no more
Old Dec 25, 2008 | 04:20 AM
smitty911's Avatar
its winter time here so no starting it lol
Old Dec 25, 2008 | 04:35 AM
i didnt know if he was starting it or not i was just putting my 2 cents in[:'(]..but yea not riding blows..the snow/the cold..geezz
