Galfer Lines Installation
Old Mar 23, 2007 | 02:10 PM
Jaybird180's Avatar
Default RE: Galfer Lines Installation
Couldn't a pro make the same mistakes? They would still avoid liability for anything other than
Leak in the line itself or the banjo fitting coming loose from the line.
I've emailed them...let's see what they have to say.
Old Mar 23, 2007 | 03:14 PM
Tahoe SC's Avatar
stop being a wimp and put them lines on already.
Old Mar 23, 2007 | 05:48 PM
Jaybird180's Avatar
They sent me back some photos and instructions on doing it myself. I had no problem with the idea of doing the work myself, just that warning gave me a moment of pause. I guess we live in a litigious society and they felt a need to protect themselves.
They did however suggest loading the lever for 3 hours with a zip-tie before the first ride. It should reveal any installation defects along with checking for binding and interference.
Old Mar 23, 2007 | 06:01 PM
Jaybird180's Avatar
They want 1 hr. labor time to do the lines. I can buy a vacuum bleeder for less than that and do it myself.Getting that reservoir cover off with the stripped screws are going to be a PITA, but I think I can bling the replacements.
Old Mar 23, 2007 | 06:43 PM
Tahoe SC's Avatar
just make a groove like this ---- across the bolt and then use a flat head to extract it. that's what i did with mine.
yes, after you bleed and stuff, use the zip tie on the lever over night.
Old Mar 23, 2007 | 08:36 PM
Jaybird180's Avatar
Seems like you need to make a Tahoe FAQ for yourself. I know you've said that at least a dozen times.
Old Apr 11, 2007 | 09:46 PM
Jaybird180's Avatar
Aight mang.
I got one screw out using a flatblade and hammer. The other is buggered pretty bad, and that WAS the good screw. Seems like they tightened since this post was made.
Any other bright ideas?
Anyone know the size screw to replace them with? I think I'll go with an allen head this time.
Old Apr 12, 2007 | 02:04 AM
mccannf3's Avatar
I am ordering the same lines right now, you guys recommended the zip tie over night on the handle bar, but what do you do on the rear brake?
Old Apr 12, 2007 | 02:15 AM
Tahoe SC's Avatar
the rear brake sucks anyway...i wouldn't waste my time on it...or you can sit on it ove night, or bunji it to the rear wheel or something. heck, duct tape a rock to it!
jay, stop buggering up everything! those screws SUCK! they are the reason i went with the gsxr unit. i say go baller and buy the brembo MC!
Old Apr 12, 2007 | 12:59 PM
Jaybird180's Avatar
I say leave the rear brake stock.
Screws and bolts go bad when you take off/ put on/ take off/ put on. It's why Honda says to replace them, soft metals I guess.
I'll reserve the Brembo MC for a future racebike (if WERA allows it).
