Fuel pump won´t stop
Old May 29, 2019 | 12:33 PM
Hraboss's Avatar
Default Fuel pump won´t stop
Hey guys, yesterday I was cleaning fuel pump on my 2007 CBR125R and accidentally i connected wrong wires - i swapped + and -. It burnt the fuse so i had to replace it, but after replacing it, the fuel pump just won´t stop. I checked all the fuses and starter relay and everything seems to be OK. After turning the key to ON position everything works - lights, neutral light, horn works, turn signals too. Only the pump seems to not work correctly. I had a new pump, so i tried to replace it, but it does the same - just won´t stop. If anyone could help me i would be thankful.
Old May 29, 2019 | 01:53 PM
CaBaRet's Avatar
Hi matey , could you lift the tank and check the Earth wires to the pump , check all the connectors below there,
Old May 29, 2019 | 11:27 PM
Hraboss's Avatar
The bike is fully dissassembled, fuel tank is off the bike, and the whole fuel pump assembly is out of the tank. I thought it might be the pressure, but it wasn ´t.
Old May 30, 2019 | 12:46 AM
CaBaRet's Avatar
No , I think its more likely to be a cross over Earth with blowing a fuse, if you like its like a bypass on the pump that keeps it running all the time, so I think its down to shorted wires somewhere around the pump circuit, will look at some test's you can try
Old Jun 7, 2019 | 05:07 PM
trachito's Avatar
Your relay may be stuck to the on position. Try swapping it with another relay.
Old Jun 7, 2019 | 09:27 PM
shawn809's Avatar
Yes, this. Sometimes when you short a circuit that involves a relay the relay will stick. Replacing it is your best option and they are not very expensive, usually less than $10.
kszx
Jun 27, 2011 11:32 PM
CrAzyHuRRicAne
Aug 3, 2008 05:16 PM
follick
Jul 5, 2008 10:45 AM
maximus3
Sep 20, 2006 12:06 PM
CivicRacerX7
Apr 22, 2005 12:03 AM
