FUEL LEAKING? Please Help!
Old May 15, 2008 | 09:01 PM
FLYIN HAWAIIAN's Avatar
Default FUEL LEAKING? Please Help!
As to my previous post. Bike has been down since the fall over when changing my oil. I gave her a tune-up today.
New plugs
New oil
New K&N air filter
Started her up and found fuel dripping out of the #1 left cylinder where the header meets the block. I called a shop and they think the float is stuck in the carbs. I am getting spark.
Any help would be great.
Any referrals to a mechanic in CO?
Anyone just have the carbs redone and how much?
Thanks
G
Old May 16, 2008 | 11:15 AM
tnorwick's Avatar
Default RE: FUEL LEAKING? Please Help!
Don't know how mechanically inclined you are but when i had the same problem i took my carb rack off and found i needed new needle valves and seats. It was only $200 for parts and labor at my friends shop, but then again i know the guys... I suggest taking the carb rack off and inspecting your needle valves and floats but like i said, i don't know how mechanically inclined you are.
Hope that helps!
Old May 16, 2008 | 01:44 PM
KidCr3nshaw's Avatar
If tune-ups are the extent of your wrenching, you might want to have the work done. Carbs aren't as difficult as they are made to be, but they need to be serviced correctly or you can just have headache after headache. A shop will probably synch them too for not much more, simple process and it won't hurt.
Just depends, you could do it yourself and have it done by early this evening or it could be in pieces tomorrow or you could have it together tomorrow, not running and havehaul it to the shop...
Kinda just depends man, definitely geta manual and take a look at the procedure. I don't know what bike you have but a member here, www.stephygee.com (username StephyGee) has manuals for free download.
Good luck.
platnumbob
Jul 5, 2014 09:57 PM
Mulkxican88
Nov 14, 2013 05:23 PM
MegatronousPrime
Apr 29, 2012 09:51 PM
robbiebgraham
Mar 8, 2011 02:47 AM
haak30
Sep 17, 2008 05:24 AM
