Fuel Injection
Old May 3, 2006 | 02:51 AM
TheSneak's Avatar
Default Fuel Injection
Hello All, Little Help Please,
So after a long torturous winter the bike is out again, but when I turn the key there is no buzz noise of the fuel injection priming... Any hints on how to fix this?
Thank you!
-Jenn
Old May 3, 2006 | 04:02 AM
dwhite645's Avatar
Default RE: Fuel Injection
If there is no buzzing noise from the fuel pump, it might need replacing. Check your fuses and battery too, just to eliminate the easy things first.
Old May 3, 2006 | 04:32 AM
TheSneak's Avatar
Well I don't think it needs to be replaced. Checked the battery and such..This happened once last year, it was an easy fix (didn't have to replace anything) But I wasn't there when it was done.. ..And the buddy that helped me out has managed a vanishing act.. [:@]
Any other ideas..?
Old May 3, 2006 | 02:41 PM
QuinC's Avatar
could be your tip sensor?
Old May 4, 2006 | 12:40 AM
CBRMadman's Avatar
what model and year, does it start/or turn over?
Old May 4, 2006 | 07:11 AM
shraz's Avatar
did u put it in run
Old May 4, 2006 | 10:05 AM
kiggy74's Avatar
ORIGINAL: shraz
did u put it in run
Don't anyone laugh, I've done this. When I first went to pick up my 1000RR. The bike was sitting out waiting for me to pick it up from the dealer. Sales guy said "hop on it, start it up. Make sure everything's ok." I sat there turning over for 30 secs before I realized the cutoff switch wasn't enabled. Reminds me of the first rule of troubleshooting - SFS - Simple First Stupid.
Old May 5, 2006 | 01:32 AM
TheSneak's Avatar
Cut off switch definitly not on. It's a 2001 CBR f4i
Old May 5, 2006 | 08:29 AM
shraz's Avatar
not on?
Old May 6, 2006 | 07:00 PM
Rx7man's Avatar
before yougo and buy a new fuel pump, assuming the battery is fully charged, disconnect the wiring harness to the fuel pump and just try getting the fuel pump to run that way.. I bet it's something pretty simple.. you can check the connectors etc that go to the fuel pump for corrosion, etc as well
600ninja
Apr 9, 2010 04:54 PM
chancyrust
May 23, 2008 03:30 PM
600rrATC
Mar 23, 2006 11:18 PM
mxman87
Jun 13, 2005 01:30 AM
