Fuel gauge reading goes crazy on cluster !?
Old Nov 24, 2008 | 09:22 PM
minur505's Avatar
Default Fuel gauge reading goes crazy on cluster !?
I ride an 2003 cbr600rr and recently the fuel gauge on the cluster stays blinking all crazy like full and then empty and then mid even when i have a full tank of gas so i was wondering if anyone knows anythin about this or if this has happen to someone ?
Old Nov 26, 2008 | 12:38 PM
Shadow's Avatar
Default RE: Fuel gauge reading goes crazy on cluster !?
Check the earthing/grounding on the tank sender unit - if it's intermittent, that would cause your problem. A partial break in the live wire would do it too, so check for continuity on both wires - they sometimes break inside the coating ,,,,,,,,[X(]
Only other cause could be a faulty sender unit, but I suspect the earth wire...
Hope it helps.
Frost
Aug 1, 2012 03:16 PM
iBang
Jul 15, 2010 12:15 PM
jacked600
Jul 6, 2009 09:08 PM
tachitup
Jul 4, 2008 05:14 PM
