front end
Old Jan 11, 2008 | 12:17 AM
tdiv135's Avatar
Default front end
i have a 02 954 that pulls to the right a little what could be the problem
Old Jan 11, 2008 | 03:53 AM
Bullswool's Avatar
Default RE: front end
A quick flick through troubleshooting would suggest possibly one of the following,
Loose or damaged steering head bearings,
Bent axle,
Bent fork,
Worn or damaged wheel bearings,
Wheel installed incorrectly,
Worn swingarm pivot bearings.
Old Jan 11, 2008 | 04:12 AM
jutsin's Avatar
roads are crowned and will push u to the right... try riding in the left lane on a road with 2 or more lanes in either direction seperated by a grass median (interstate), should push you to the left...if it does, no problem, if you still drifting to the right, then u have a problem
Old Jan 11, 2008 | 07:49 AM
Ty's Avatar
Ty
On what jutsin was saying, if you ride a lot on straight roads that are graded like the right lane on the slab or on country roads, your tire will begin to wear unevenly and pull you to one side. You may just need to check your front tire for wear.
Nero
F4i - Wanted
Jul 31, 2011 03:22 PM
bammerman
F3 For Sale / Trade
35
Aug 4, 2010 09:40 AM
TMAX
CBR1000F Wanted / Swap
Nov 18, 2009 12:41 PM
Hayden06F4i
May 3, 2008 09:35 PM
