front brake not turning tail light on f2
Old Jun 6, 2013 | 05:58 PM
geoguyxfi's Avatar
Exclamation front brake not turning tail light on f2
hello guys so my first thread woot!!! and i need help my rear brake lever activates my tail light but my front brake leaver does not it makes the "clicky noise" though. i dont believe the wires or connectors are oem. and i do not have a manual.
on the front brake there are 2 electrical connectors what are they? Hot in/hot out? i have been doing some probing with a test light and no light has been coming on.
Old Jun 6, 2013 | 06:15 PM
74demon's Avatar
Touch the two wires together. If the light comes on, replace the switch. You can try cleaning it first if you want to. There is a thread about it somwhere around here.
Old Jun 6, 2013 | 06:30 PM
geoguyxfi's Avatar
just tried it. still just running light comming on.
nothing changed
i tried what you said and nothing happened
thelight did not come on help please have ride in am!
Old Jun 6, 2013 | 07:57 PM
You say that no light has been coming on. Are you referring to the light on the Test Light tool ? If that is the case, and you've got the tool properly connected, then you probably don't have the 12v supplying the Front Brake Light Switch. The connectors for the wiring harnesses that feed the switch are located behind the gauge cluster. There is a 4P connector and the Black/Brown wire should have 12v on it all the time. See if you have that. Your test light should light up if you put it on that wire.
Old Jun 6, 2013 | 08:31 PM
Conrice's Avatar
they're both hot. the brake light is grounded separately. the switch makes and breaks your positive connection to the taillight, thus turning it on and off. make sure the switch isn't dead. i've had a few over the years go out on me. the ones that have broke don't make the "clicky" sound. so as demon suggested, make the connection between those two wires. if it still doesn't light up, you know the problem is elsewhere. there are connectors under for the handlebar wires too - it could be that a contact has become corroded in that connector. grab a wiring diagram and get to it
Old Jun 6, 2013 | 08:45 PM
geoguyxfi's Avatar
where do i get a wiring diagram i dont have a book i have mounting problems with my cluster so that makes sence i am going out to play some more keep ideas comming please i am lookin for it now!
Old Jun 7, 2013 | 03:56 AM
Dean0's Avatar
Have you tested the BULB to see if it has gone ?
Old Jun 7, 2013 | 09:04 AM
jeason15's Avatar
Stephygee.com for the manual. Skip the intro and look at the bottom of the he page. Manual is on that page, wiring diagram is in the back of the manual.
Old Jun 7, 2013 | 09:38 AM
74demon's Avatar
He says the brake light works by the rear switch. If this is true, the bulb works.
Old Jun 7, 2013 | 10:50 AM
geoguyxfi's Avatar
that is correct rear switch turns tail light on but not front. i will buy a voltmeter today after the ride and do some more hunting tonight. thanks guys.
