Front Brake Lever Sticks
Old Jun 9, 2011 | 08:28 AM
Monty08's Avatar
Default Front Brake Lever Sticks
I installed a new front brake lever and when I squeeze it, it seems to stick a bit so the taillight stays on and not release.
Any ideas?
Thanks
Old Jun 9, 2011 | 12:38 PM
txsmainevent's Avatar
1. Take off the brake lever, hit the area where it pivots under the bracket with sandpaper to "reduce its size" Just to clarify sand the lever not the mouting bracket.
2. On the bottom side of the bolt that bolts is in is a nut (or there should be one). Its usually a lock nut and that bolt/nut should not be super tight. If you tightened it down it will cause it to stick. It has a lock nut so you can have it slightly loose and still not lose the bolt....
Old Jun 10, 2011 | 08:11 AM
Monty08's Avatar
Thanks, I will give that a shot this weekend and let you know how I make out!
Jnymack123
Aug 24, 2010 12:28 AM
6doubleohf3
Oct 25, 2009 09:01 AM
duckorbleed
May 20, 2009 11:06 AM
Draco88
Aug 13, 2006 11:30 PM
aeroworks
Feb 23, 2006 01:21 PM
