Freeway grooves
Freeway grooves
So I was driving home the other night on the freeway (car, sadly) and hit a long patch of grooves on the freeway that extended all the way down the offramp which had a slight turn to it. They were pretty rough and had a slight drop off of about 2 inches.
It made me think, how would you handle grooves like this on a bike? Any suggestions / comments?
on
1 Post
Do you mean the grooves where they take up the a section of road & reveal the 'Base' before they reseal it again? If so 1st time I hit on of those was years ago on a foggy morning commute.Doing a 110 KPH (68ish MPH) Road dropped by about 4-5 inches & suddenly no bloody traction & the rear started to fish tail all over the place, then whump, hit the the other rim where the unsealed road ended, lifting the front wheel, then the rear & now my feet come off the pegs as my **** gets thrown in the air. Needed fresh undies when I got to work. Now they put up "Motorcycle Hazard" signs.
The first time I ever encountered that was on a back road where they , at some point in time, had sparyed tar & gravel on the road but the gravel was long since gone BUT it stuck to where the tar lines were making grooves. I slowed down and the bike seemed to "wobble" but later found out they were much easier to hit them at a bit faster speed around 40 or 45 MPH instead of slowing to about 25MPH. I've seen the grooves you're talking about but just use a little caution and adjust speed to what you can handle.
I hit those few weeks ago. I went to work in the morning and street was fine. Then when I was going home, it said "rough road ahead" and air was very dusty. I could not change lane to good surface because it was like 2 inches higher. It went on for 3 blocks. Bike was following the grooves and was very uncomfortable but it was ok. Although I would not go on it on purpose. I think I was stiff....
Zandaloo
08-22-2013 03:26 PM
