fouled sparkplug only #4 cylinder help!
Old Nov 21, 2005 | 01:15 AM
allday's Avatar
Default fouled sparkplug only #4 cylinder help!
#4 cylinder fouls sparkplug after i ride for awhile turn it off and start up after awhile. all the jets in carb are tight and clean.what might cause this besides bad valves. only #4 is doing it???
Old Nov 22, 2005 | 03:19 AM
shraz's Avatar
Default RE: fouled sparkplug only #4 cylinder help!
the sparkplug itself
change it
Old Nov 22, 2005 | 11:04 AM
doncollins's Avatar
Retired Administrator
He stated only #4 is doing it, as in more than once... right? Have you had the carbs adjusted/tuned? Sounds like #4 carb is running a little too rich.
Old Nov 22, 2005 | 08:18 PM
slowpoke's Avatar
Sunk float, misadjusted float, bad or clogged float needle and/or seat, or sticky diaphram slide that is hanging open. You could check the compression to see if the rings and valves are good. You could also check the resistance of the spark plug wires, but if the spark plug is firing, it's probably the carb, since number 1 and 4 cylinders share the same coil.
Old Nov 23, 2005 | 03:16 AM
allday's Avatar
t
Old Nov 23, 2005 | 03:25 AM
allday's Avatar
its happend more than once. i checked the coil and wire and those are good. could it be the air screws can that cause it.if so where in carb are they.the people that did my jet kit didn't plug regulater back in but if that was it wouldn' all carbs. do it??
gride99
Aug 30, 2009 06:07 AM
mauthman
Jul 9, 2008 12:43 AM
swalker
Jun 21, 2008 06:06 PM
