flush mount question...
Old Feb 16, 2007 | 12:35 AM
schizcat's Avatar
Default flush mount question...
I installed flush mount leds on the front and shorter leds on the rear after FE kit. I got a motrax relay so I wouldnt have to go thru the trouble of installing resistors. my question is A) Has anyone installed one of these before and 2) Where is the signal relay? I have an 06 600rr. Ive read that on the 1000 rr, its on the left fairing, wouldnt this be the same for the 600? If not, could some one direct me to the right place. Thanks
Old Feb 16, 2007 | 01:16 AM
knightslugger's Avatar
Default RE: flush mount question...
The relay is in the gauge cluster, so you'll need to tap into the wire harness.
http://600rr.net/vb/showthread.php?t...ight=resistors
booya.
Old Feb 16, 2007 | 01:23 AM
schizcat's Avatar
ok, i saw this and have my front fairing off, but which wires do i tap into? there are actually 2 green wires that look like they go to the flashers.
Old Feb 16, 2007 | 01:25 AM
- Cut the white/green wire.
Old Feb 16, 2007 | 01:27 AM
schizcat's Avatar
rgr...but i have a black and a red coming off the relay. what goes to what? sorry about the Q&A...im and electrical idiot.
Old Feb 16, 2007 | 01:31 AM
just..... follow the directions in the 600RR thread.
Old Feb 16, 2007 | 01:32 AM
schizcat's Avatar
well, they guy never says what wires to cut. only to run the black and red wires thru.
schizcat's Avatar
nm.....found it.
Old Feb 16, 2007 | 02:18 AM
dragonium25's Avatar
Resistors are so much easier to deal with. Just hook 'em up in parallel and you're done. You're splicing wires to put your new lights in anyways, what's an extra 2 mins to hook up the resistors.
Old Feb 16, 2007 | 09:36 AM
but resistors aren't a permanent solution to the problem.
