fixing squishy suspension
My '90 f1 has really soft suspension, and I get the feeling it's just an age problem, not something wrong with the bike per se. I'd looked at buying an aftermarket rear shock, but that's like $1000, a lot more than I'm able to invest at present.
My second idea was to swap in the rear shock from a 600 rr (readily available on ebay for under $30) but it looks like the connections are so different as to make it nearly impossible.
Yesterday, my friend suggested that I may need to only replace the spring, and not the entire shock. Does that sound like a good option? if so, where would be a good place to get a replacement spring?
I'm just tired of bottoming out on speed bumps...
Or try finding a parts bike on E-bay , or a local bike salvage yard to get one off of . I'm not positive , But I believe that yr did have a bit of a soft suspension on them ,, I don't think they are adjustable till the f-3 / f-4 , but like dagon said,,it will work ,,,as I've seen them on the f-1's , and you'll have to mount the reservoir on the subframe under the airbox I believe . But be forewarned , it raises up the rear pretty good and may throw your center percentage off balance a bit. Check around on craigslist or e-bay for aftermarket or oem mono's.
![Icon Shrug](https://cbrforum.com/forum/images/smilies/icon_shrug.gif)
I'm also just going to get a new spring for my F4. At 200 lbs I'm a bit too heavy for the stock spring and although my sag is set for my weight, the pre-load is set at 5 (out of 7) so I don't have much travel left. Same for the front, which is set to max pre-load. The 'best' option for me ($$ wise) is to just get new springs front and rear. I don't race so getting a full suspension upgrade is a waste of money (well, it will probably quite good but I don't have the money for that
So yeah, just look for a shock. It's only a 100 bucks or so (can't give you any websites, I'm not in the US).
![Stick Out Tongue](https://cbrforum.com/forum/images/smilies/tongue.gif)
Thanks for the advice! I'll start poking around for an f4 shock.
If it raises it up, should I look into lowering the bike to counteract it? seeing as my bike is too low I haven't red up on it much yet.
Update: Looks like I should be able to get it for as little as $40 plus shipping easy![Big Grin](https://cbrforum.com/forum/images/smilies/biggrin.gif)
Update 2: (maybe I should start a new thread for this question...)
It looks like I can get a whole back swing arm for not much more, which tempts me to try to replace that to put wider rubber on the back... how easy of a mod would that be?
Update 3: I looked into lowering a little, and the concept seems simple enough. Looks like if I throw a lowering link in there the ride hight problems should be nullified. I found a couple f4 shocks on ebay, _with_lowering_links_. Offered $35 for one (down from 40) and with $15 SnH sounds like a good deal to me. When and if I get one, I'll be sure to post up details of the swap!
Thanks again for the suggestions! got really bummed after seeing the RR linkage.
I meant to just get a new spring, not a whole shock. Although the F4/f4i shock is pretty decent I think.
Thinking about it.. if it feels soft and spongy, it might not be just the spring... It's the oil/gas that regulates the rate of compression/rebound right?
In that case I would suggest replacing the whole thing instead of just the spring. Makes more sense in your case. I want to change the spring just because of the spring rate.. Is the front spongy too. I just changed my fork oil and it feels more solid (in a good way).
