first time spark plug change
Old Jun 3, 2006 | 12:16 AM
kingmal's Avatar
Default first time spark plug change
Hey Guys,
I'm a noob so please excuse my simple questions. I have a 2000 CBR 600, I am trying to change the spark plugs and i wanted to know, exactly how do you get them out. I got the ignition coil 4 out buy turing it to the left 6 or 7 times and then pulling it up. the ignition coil came out but the spark plug did not. I dont know if i did somthing wrong and the spark plug is still in the engine or if the guy i bought it from did have one in there although it was working fine for like 3 months after i bought it. can some one help me out.
Old Jun 3, 2006 | 12:23 AM
uansari1's Avatar
Default RE: first time spark plug change
Um... it doesn't sound like you know much about motors. Maybe you should take the bike to a pro.
If you still want to attempt it yourself, you should know that the coil and plug are separate parts. Now that you have the coil disconnected, you need to use a spark plug socket and unscrew the plug, then pull it out. It will help if you have a magnetic screwdriver or something to fish it out.
Old Jun 3, 2006 | 01:20 PM
05Tribal's Avatar
Kingmal is right the spark plugs are screwed into the head over each cylinder. On engines like ours, strait fours, there is one spark plug for each cylinder as opposed to two per like on some V-Twins. They are screwed in kind of tight so the compressed air that builds up prior to and after spark detonation does not escape past each plug. Do the work yourself but first buy the service manual.
Old Jun 7, 2006 | 05:45 AM
ciupe's Avatar
Spark plug is easy, just lots of work.
I followed this tutorial and it was cake
http://www.bossturbo.com/cbr/howto_sparkplugs.shtml
Get the tool kit for your bike off ebay, bout $15. Its got that spark plug attatchment that makes things easy.
Disconnect the electrical wires fromcoils. Pull up on it, it comes right off. Drop in spark plug attatchment, unscrew and remove spark plug. Remember righty-tidy , lefty-loosy. Do not cross tread spark plug in there when putting in new ones.
Go do it its easy.
[IMG]local://upfiles/4194/370D5DA91D9F499BBE5B008CB5A25CA9.jpg[/IMG]
[IMG]local://upfiles/4194/7E998AA7C5A14A59964CF53E0F288899.jpg[/IMG]
rapidspec
Jan 14, 2015 04:04 PM
MARCD1
Jan 9, 2012 09:49 PM
Stoner
Mar 20, 2011 08:15 PM
sixs929
Jun 1, 2006 06:51 PM
CivicRacerX7
Feb 13, 2005 02:08 PM
