Finally did a compression test on my bike
And I must say... not too bad! I think they actually would be better though if I had the correct fitting for the compression tester. The coupling I have is the right diameter and thread pitch for my cyl head, but it's about half the length of the threads on the plugs, so it's not long enough to thread in with the proper o-ring. I had to end up using a dinky little a/c o-ring which was thinner and did affect my readings some because it only threaded on maybe one turn (it was leaking a lil bit at one point). Had I used the correct fitting (which I can't seem to find anywhere) I have a feeling they would have been damn near spot on
Readings were....
cyl 1 - 175 psi
cyl 2 - 165 psi
cyl 3 - 170 psi
cyl 4 - 165 psi
The spec in the manual is 178 psi, so even with the coupling that didn't fit quite right, they were all still pretty close!
Plugs still looked pretty good too (had 38k miles on these plugs).... that's a very good thing, means she's running the way she should be (although I know it might be a lil rich cuz I need to have my PCIII tuned)
Oh yea air filter was looking pretty dirty too so I cleaned it out and re-oiled.... gotta get her all ready for this months round of roadtrips! LOL
Readings were....
cyl 1 - 175 psi
cyl 2 - 165 psi
cyl 3 - 170 psi
cyl 4 - 165 psi
Compression wise, you look like you got 'er where you want 'er, good job on that! But fuel wise, correct me if i'm wrong, but...
I believe by the white color on the end of your plugs, you're running a little lean, (somebody correct me if i'm wrong, but dark and goopy would mean rich, right?) a little lean is ok. as is a little rich. You're pretty close, regardless. If anything, I'd richen it down a notch, just to see the results. If I'm completely wrong, then i've been misinformed.
Ieathonda
Jun 6, 2015 05:39 PM
Kopi Ko
Jun 30, 2013 03:49 AM
